Undiagnosed z-artifacts January 25, 2015 08:48PM |
Re: Undiagnosed z-artifacts January 26, 2015 11:46AM |
Re: Undiagnosed z-artifacts January 26, 2015 12:42PM |
Dirty Steve
you definitely want your hobbed bolt to be better than that.
If you have restraining bearing on your Z axis threaded rods, remove them.
Re: Undiagnosed z-artifacts January 26, 2015 02:30PM |
Re: Undiagnosed z-artifacts January 26, 2015 03:25PM |
I understand. What I have read is that constraining the z axis screws at the top will cause the x carriage to move around if the screw is bent (z wobble), but if the x carriage is completely decoupled from the x carriage then theoretically it won't move around at all from a bend in the Leadscrew right?Quote
Dirty Steve
I'm referring to a 608 bearing on the end of your lead screws, opposite end from your Z motors, if your setup has them, not the attachment to your X carriage. I make my own hobbed bolts, I had one that was 'out of round' like yours, correcting that was my final Z artifact fix on my printer. It causes different amounts of material flow.
Re: Undiagnosed z-artifacts January 26, 2015 03:52PM |
Re: Undiagnosed z-artifacts January 26, 2015 04:09PM |
Re: Undiagnosed z-artifacts January 26, 2015 04:19PM |
Maybe I should be more clear... This is why I don't think it is wobble becuase i purchased high quality anti backlash nuts which are far superior to those diy nut traps, and yes, by uncouple, it guides along the smooth rod like that and pushes up the x carriage. The x carriage is in no way attached to the z nuts, meaning I can pull it up and it moves down with gravityQuote
Ano
It's possible by "anti-wobble" mechanics, for example this one:
http://www.thingiverse.com/thing:141479
or that one:
http://www.thingiverse.com/thing:33053
Re: Undiagnosed z-artifacts January 26, 2015 05:04PM |
Re: Undiagnosed z-artifacts January 26, 2015 05:30PM |
Re: Undiagnosed z-artifacts January 26, 2015 05:38PM |
It is a cube with equal sized sides all the way up. For my hotend, I wrapped Ptfe tape around it so it is stiff in the jhead mount, and to furthermore expel and movement/vibration errors i printed painfully slow, about 10-15 mm/s and this took a good 2 hours to print, rather than a normal 30 mins, and the quality was the same on both.Quote
Dirty Steve
It could just be your hobbed bolt. Double check that your hot end assembly doesn't have any wobble in it's mount.
Is the Artifacts.jpg print you posted single wall?
Re: Undiagnosed z-artifacts January 26, 2015 11:04PM |
Ano
I was just answering Steve, because I have no idea, what it could be. Perhaps your bolt is causing some effect that add up with others or something.
If you didn't look up this wiki-page, perhaphs you can finde a cause (or multiple ones) for your problem: http://www.reprap.org/,
but other than that, I'm sorry to say, but I don't know.
You are not using a bowden setup, are you?
And your filament is without problems, for example air bubbles or diameter changing (like 1.75mm being between 1.5 and 2.0)
Re: Undiagnosed z-artifacts February 05, 2015 11:43PM |
Re: Undiagnosed z-artifacts February 06, 2015 09:27AM |
TheReprapExperience
Re: Undiagnosed z-artifacts February 06, 2015 05:08PM |
Re: Undiagnosed z-artifacts February 06, 2015 08:25PM |
Re: Undiagnosed z-artifacts February 06, 2015 10:45PM |
Re: Undiagnosed z-artifacts February 06, 2015 11:25PM |
Essentially I have my leadscrews seated ony motor shafts so that the coupling does not compress with the weight of the x carriage.Quote
Dirty Steve
Is the spring part of the couplers collapsed from the weight of the X carriage? I have top mounted motors on my machine, but I recall a tread somewhere about placing a 4mm ball bearing inside the couplers, to space the lead screw off on the end of the motor shaft, and to expand the flex part of the couplers.
Re: Undiagnosed z-artifacts February 07, 2015 01:20AM |
Re: Undiagnosed z-artifacts February 07, 2015 10:58AM |
Re: Undiagnosed z-artifacts February 07, 2015 01:51PM |
That's what I thought, but I printed the towers with no heating to rule that out. It does remain consistent though so it's probably using default PID'sQuote
the_digital_dentist
Bed temperature variation can cause Z-artifacts. Are you using bang-bang or PID control? Does the bed temperature remain reasonably constant during printing?
Re: Undiagnosed z-artifacts February 07, 2015 03:11PM |
Re: Undiagnosed z-artifacts February 07, 2015 03:33PM |
That's what I thought at first, but I printed another tower while holding the filament keeping plenty of slack and there was no difference in the wall smoothnessQuote
Rayton
Could it be an issue with the way the spool is mounted? Sometimes the tension from the filament might be pulling up the extruder, and then when that tension is released from the filament spool turning a little, the extruder moves back down.
Re: Undiagnosed z-artifacts February 09, 2015 12:01AM |
