Problem with Z axis
January 30, 2015 09:45AM
Hello everyone
I am trying to build a printer using a printrboard. I have assembled the outerbody of the printer and configured the electronic cables, the motor positions, etc, am using pronterface as the command software . I am able to move the x and y axis .. but the z axis is giving me some problems. there are 2 motors in the z axis and they rotate in the opposite directions when i try to move the z axis. the motors are working fine. and i have double checked on the cable connections.
Would be glad if someone helped me with this.
Thanks in advance
regards
kailesh
Re: Problem with Z axis
January 30, 2015 10:29AM
You should be able to change the direction of one of the Z-axis steppers by flipping one of the stepper plugs on your board...
-David
Find me online at:
Thingiverse
Instructables.com
LinkedIn
Facebook
Check out my FolgerTech Prusa i3 (plexi) at MindRealm.net
January 31, 2015 03:45AM
Thanks for the reply David .. will try that out and post the outcome.
