Test cube failure need help please! February 10, 2015 12:49PM |
Re: Test cube failure need help please! February 10, 2015 12:51PM |
Re: Test cube failure need help please! February 10, 2015 02:57PM |
Re: Test cube failure need help please! February 10, 2015 02:59PM |
Re: Test cube failure need help please! February 10, 2015 03:04PM |
Re: Test cube failure need help please! February 10, 2015 03:05PM |
nerdegutta
Disconnect all, check wires, re-connect one wire at a time, restart software. Maybe try another heater, if you have a spare...
- nerdegutta
Re: Test cube failure need help please! February 10, 2015 03:19PM |
Re: Test cube failure need help please! February 10, 2015 03:21PM |
Re: Test cube failure need help please! February 10, 2015 03:24PM |
Wisar
Measure the resistance of the thermistor across the leads connecting it to the controller. I think it should be around 100K but you should check your thermistor documentation. If it is not what it is supposed to be then find out why!
Re: Test cube failure need help please! February 11, 2015 01:56AM |
Re: Test cube failure need help please! February 11, 2015 01:36PM |
Wisar
Anyone with a RepRap printer should probably have a Volt Ohm meter. You can get them cheap:
Cheap Meter
A Thermistor is basically a heat sensitive resistor and has no polarity. But it could be defective or you could have a short. Hence the meter.
Wisar
Re: Test cube failure need help please! February 12, 2015 12:41PM |
Re: Test cube failure need help please! February 12, 2015 12:51PM |
Re: Test cube failure need help please! February 12, 2015 12:53PM |
Kurzaa
I didn't think you could solder thermistors as the heat would crack the glass. Obviously that doesn't make sense as we use them to measure heat, but why else would they come with the clamped ferules?
I was also wondering if the problem might be with the calibration of your Z steps per mm. Perhaps it was just slightly to small and it took half the print for the issue to compound itself enough to start dragging through the previous layer.
Anyway, sorry you encountered so many issues with your printer. I know how that goes. Hopefully you will come back to it someday and get it working correctly.
Re: Test cube failure need help please! February 12, 2015 02:36PM |
Re: Test cube failure need help please! February 12, 2015 02:46PM |
Re: Test cube failure need help please! February 13, 2015 01:04AM |
Re: Test cube failure need help please! February 13, 2015 05:50PM |
Wisar
It will be interesting to hear your experience with the CTC printer. It is an amazing, though expected statement about the evolution of the technology that you can now get an assembled dual extruder reasonable print volume printer for less than 500 dollars (or 400 pounds here in the UK).
Re: Test cube failure need help please! February 15, 2015 02:02AM |
Re: Test cube failure need help please! February 15, 2015 01:16PM |
Wisar
Any change that you could try to print this?
Bridges Torture Test
It is causing my printer fits! I would be interested to see how the CTC handles it out of the box!
Wisar
Re: Test cube failure need help please! February 15, 2015 04:27PM |
Wisar
Wisar
Re: Test cube failure need help please! February 15, 2015 09:26PM |
Re: Test cube failure need help please! February 15, 2015 09:45PM |
tmorris9
Umm.... The whole point of a bridge test is to see how it prints WITHOUT support.
Re: Test cube failure need help please! February 16, 2015 03:01AM |
Admin Registered: 12 years ago Posts: 3,096 |
Re: Test cube failure need help please! February 16, 2015 06:25AM |
Re: Test cube failure need help please! February 16, 2015 10:20PM |
Re: Test cube failure need help please! March 12, 2015 03:00PM |
Re: Test cube failure need help please! March 12, 2015 04:01PM |
Re: Test cube failure need help please! March 12, 2015 04:12PM |
