Incorrect Z axis hight while printing February 17, 2015 03:38PM |
Re: Incorrect Z axis hight while printing February 18, 2015 03:12AM |
Re: Incorrect Z axis hight while printing February 18, 2015 08:32AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {82.524592328, 82.524592328, 2026, 700} // default steps per unit for Ultimaker
Re: Incorrect Z axis hight while printing February 20, 2015 01:22PM |
Re: Incorrect Z axis hight while printing February 21, 2015 05:57AM |
Re: Incorrect Z axis hight while printing February 21, 2015 06:56AM |
Re: Incorrect Z axis hight while printing November 08, 2020 10:15PM |
imqqmi
I've had the same issue with the prusa i3. Here's what can cause it and fix it:
- slipping z rod to stepper motor tubes. Replace it with a coupler. To test, mark motor and tube with cd marker. Lubricant can leak down the z rod.
- rod wire can have a deviation. I've used a 1200dpi flatbed scanner and counted the number of pixels for 100 turns and calculated what the z steps should be.
- calibrate the stepper motor voltage so that it doesn't produce noise when sitting still.
- use auto bed levelling as the z adjustment screw can be hard to set correctly. I use a 9g servo with microswitch with consistent results
- the z rod nut that goes into the x end and x motor mount is too loose sometimes. I use a small piece of rubber so it's stuck tighter in place. It can still come loose if the head crashes into the bed so no damage can occur. This helps auto bed levelling accuracy and consistency.
- calibrate the z offset when using auto bed levelling and measure the z height of one printed layer. I use a perimiter or skirt for this.
- make sure the z velocity is set to 3 instead of 5 which can cause missed steps. Make sure you set it in the correct place, depending on your configuration, within the firmware, recompile and upload, or using the display and control knob in control/motion. Make sure to store settings in control menu.
- lubricate all moving parts except the stepper motors, I think these are sealed anyway.
- calibrate the x axis being parallel with the print bed. I use a credit card slipped under the x smooth rod and on the bed with the 55mm side left and right. If it has about the same resistance you're golden.
- level the bed too of course, even when using auto bed leveling it's better to have it level in the first place. The bed, x rod angle and z offset can give an error of about 0.5mm, which can be the difference between parts just not fitting properly.
Hope this helps!
Good luck!
