Printing With Flex...Help?
February 27, 2015 02:55PM
I'm trying out some Flex filament from Torwell.
I can get it to print, but it seems to collect some on my print head (Standard J-Head .4mm) and then drop blobs into the print.
My working settings are:
bed 70c
Tip 205c
Any advice on flexable filament may be useful. Never used it before.
Thanks,
Re: Printing With Flex...Help?
February 27, 2015 03:52PM
Ive recently printed with some white ninja flex and found that gooey on the nozzle as well.
I cleaned it between prints. Its very sticky stuff.
I used 230degC for nozzle and about 60 for bed with just clean mirror glass.
It did ooze a bit and i had to watch for the start of the print to pull the ooze away.
Maybe a bit hotter to flow better and not get stuck to the nozzle?
Gordon
February 28, 2015 07:04AM
I have yet to find any flexible material that does not ooze. Most of the flexible stuff i print holds well on glas with PVA glue.
The most limiting factor is a reliable extruder. I created my own[www.thingiverse.com], which worked quite well, but then a friend made a better one [www.thingiverse.com]
SInce each material has it's own range of temperature you will have to check for the exact type, or just try it out.
I found that you can get extremely good results with this [www.plastink.com]
It prints very much like ABS
Cheers
Björn
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
March 01, 2015 04:09PM
Thanks All!
Higher temp did keep the filament from building-up on the nozzle.
However, I do think my current extruder is having trouble gripping the filament.
Again thanks,
March 02, 2015 06:29AM
Ive got a direct wades reloaded with no modifications for flexible filament and had to slow it down to 30mm/s to stop the ninja flex from bunching up.
And had to loosen of the grip on the hobbed bolt a bit. As it was just deforming the filament and deflecting the path a bit in the extruder.
I normaly print at 50mm/s for abs.
Gordon
Edited 1 time(s). Last edit at 03/02/2015 06:31AM by gordonendersby.
