Wavy Layers?! April 03, 2015 09:40AM |
Re: Wavy Layers?! April 03, 2015 10:17AM |
Re: Wavy Layers?! April 03, 2015 10:44AM |
Re: Wavy Layers?! April 03, 2015 01:55PM |
Re: Wavy Layers?! April 03, 2015 02:22PM |
Re: Wavy Layers?! April 04, 2015 02:30AM |
Re: Wavy Layers?! April 05, 2015 09:12AM |
Re: Wavy Layers?! April 05, 2015 10:21AM |
Re: Wavy Layers?! April 05, 2015 10:31AM |
gadittri
Ayouden,
Your problem looks a lot like mine. I believe mine was solved by switching to a solid state relay for the heated bed. The relay that I was using was causing huge temp swings.
[forums.reprap.org]
Re: Wavy Layers?! April 05, 2015 02:10PM |
Re: Wavy Layers?! April 05, 2015 04:29PM |
Using cheesy components like (often) bent screws, under-sized guide rails, sloppy bearings, and inadequate frame rigidity (laser cut plywood, etc.) are common ways to reduce printer cost. The result is a machine that provides marginal print quality and requires frequent adjustments such a releveling and zeroing the bed after every (or almost every) print. Recently, auto tramming has become very popular. It is a software solution to the cheesy hardware problem. A $5 (retail) inductive sensor is cheaper than building a sturdy printer that doesn't require frequent adjustment.
