Temperature lock
Posted by parallaxbeta
Temperature lock
April 05, 2015 02:43PM
My RepRap Prusa Mendel V2 is refusing to print at anything other than 200C. Since my ABS seems only to work at temperatures at around 230C, this is a problem. It is going through all the steps of printing fine, but without the actual printing. Can anyone help me with this?
Thanks in advance!
Re: Temperature lock
April 05, 2015 07:18PM
Could you expand on the things you do when you prepare to print. And what are the temp settings in your slicer? Etc etc.
Edited 1 time(s). Last edit at 04/05/2015 07:18PM by Ohmarinus.
http://www.marinusdebeer.nl/
April 05, 2015 07:25PM
Check your configuration.h file, I thought there was a max temperature setting in the firmware.
April 06, 2015 03:05AM
Sketch uses 45,408 bytes (17%) of program storage space. Maximum is 253,952 bytes.
Global variables use 2,613 bytes (31%) of dynamic memory, leaving 5,579 bytes for local variables. Maximum is 8,192 bytes.
avrdude: stk500v2_recv(): checksum error
avrdude: verification error, first mismatch at byte 0x3150
0x48 != 0xf4
avrdude: verification error; content mismatch
Oh dear. The upload seems to be unhappy.
April 06, 2015 05:44AM
Kurzaa
It is set at 275
April 07, 2015 03:20PM
Does this imply that my EPROM is defective, writing one thing, but reading another
April 08, 2015 03:44AM
Ohmarinus
I set the temperature to 230C on the hotend, and 110C on the bed. I use Pronterface, because it's the only one that connects to my Prusa Mendel V2.
