hi,
I recently tried a version of cura 15 because a particular part refused to slice properly in scli3r. When i printed the part the walls of the part ended up 0.2 mm thicker than what they should be. Then i got curious and printed another part on the same printed one sliced with cura and one with slic3r. This part in slic3r came perfect in dimensions ( wall thickness 2mm came 1.98mm) but in cura it was printed thicker ( 2.2mm) . i need parts to interlock hence the accuracy. Also the parts printed in cura have a rough outer finish like it is putting in more material.
i must be making a mistake somewhere. any cura experts here?
printer 3dr delta
nozzel 0.4mm e3d v6
layer height 0.25mm
slic3r.inicura.ini
