FRUSTRATING!! - Print quality or weak print
April 18, 2015 03:07PM
Hello Printers!
I have an issue....
I am trying to calibrate my printer. And i can get pretty results, with close to no misshaping due to heat.
How ever, at this temperature, the printed parts are very weak! and is likely to snap off in the layers..
So my question is...
Why am i seeing the following:
Or my prints are too weak.....
On the pictures above, i am printing around 200 degrees celsius.
My Slic3r config bundle is here:
Slic3r config bundle (Repetier)
What am i doing wrong?
Edited 1 time(s). Last edit at 04/19/2015 11:47PM by Kafledelius.
Re: FRUSTRATING!! - Print quality or weak print
April 18, 2015 05:24PM
And... Theres Also a huge tear on tear on the back.
My printer has a cooler on the front and back. Both on 4.11 cfm.
April 19, 2015 12:42PM
Can nobody help me? sad smiley
April 19, 2015 01:32PM
images don't load.. but it sounds your heat is too low and not fusing the layers.
PLA or ABS or??
April 19, 2015 03:16PM
PLA
Sorry for the bad images! Its a dropbox link. Ill fix it when i get near a computer..
I agree, its NOT fusing.. But If i turn the heat up, it seems the plastic "collapses" As Seen on the images (Which is In the dropbox link)..
April 19, 2015 03:25PM
Do you have cooling fans? The only way to fix the delamination is to print hotter, so you need to cool the print, or print slower.
April 19, 2015 11:37PM
Yes, i have 2 4.11 cfm fans mounted on the front and back og the x-carriage... Mayer They are too weak?
April 19, 2015 11:47PM
The images are now fixed.
April 20, 2015 08:55AM
I would say yes, your fans are too small. I have 2- 9 CFM fans on mine, and I find I have issues on some bridging. My plan is to upgrade to a blower style or higher CFMs. You can test with some bridging calibration pieces.
April 20, 2015 09:07AM
Aha, are they also 40mm?
Where do you buy them? Ebay?
April 20, 2015 10:25AM
try printing a tad slower.
April 20, 2015 11:43AM
Yes, ebay. They are 50mm
