[Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 03:05AM |
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 03:32AM |
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 05:22AM |
dc42
The achievable accelerations and printing speeds depend on the printer design, and you haven't said what printer you have. My Ormerod (Cartesian) printer works well at 1000mm/sec^2 acceleration, and my Kossel (delta) can handle at least 2000mm/sec^2. I slice using 30mm/sec for perimeters, 21mm/sec for external perimeters and 50mm/sec for infill. But these figures are conservative, and after the first layer I often turn my Ormerod up to 150% speed and my delta up to 200% or even more - which means I am printing long infill moves at 100mm/sec or more on the delta.
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 05:53AM |
dc42
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 06:13AM |
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 07:30AM |
dc42
I have just checked, and I am actually using 800mm/sec^2 on X and Y axes of the Ormerod, not 1000mm/sec^2. I increased the motor currents to 1000mA from the default of 800mA, although I am not sure this is necessary. Print quality is good at 100% speed, acceptable at 150% speed, and poor at 200% speed (all using the same acceleration setting).
However, I see that in October last year, RepRapPro reduced the acceleration from 800 to 500mm/sec^2 in their default config.g file for the Ormerod. So maybe I'll try 500 and see if print quality gets even better.
Re: [Discussion] Distance, default acceleration and "plausible" speed April 19, 2015 07:50AM |
