Calibrated but prints still bumpy
May 03, 2015 09:26PM
So I have completed all calibration, but when I run a full new print I get "waves". I have attached what I mean. I have a basic set up prusa i3 with only a mk7 And plan to upgrade, but I have seen mk7 prints much better than what I am getting.
Re: Calibrated but prints still bumpy
May 03, 2015 09:30PM
Failed to mention Abs at 225.
May 04, 2015 10:39AM
Speed?
May 04, 2015 07:33PM
Yeah I was starting to think that it is maybe from it being to slow. Filament is being extruded faster than printer is moving, so it has no where else to go but make those little loop/waves off to the side. Its just weird that all the calibration objects came out super smooth.
Edited 1 time(s). Last edit at 05/04/2015 07:33PM by drHEEB.
May 04, 2015 07:58PM
If that is the case, what you need to modify is the feedrate.
Calibration cubes are basically streigh lines.... That pokemon have several slow downs and accelerations in small spaces.
May 05, 2015 06:47PM
Yeah I will try by 5 percent and then narrow in from there.
May 05, 2015 09:11PM
One thing that helped me a lot was to reduce Jerk and Acceleration values:
Change this one to 15 instead of 20
#define DEFAULT_XYJERK 20.0 // (mm/sec)
Change X and Y to 3000 and then move up until you find a sweet spot and E will depend on type if direct drive go up from 1800 and if geared from 700. Z can go up to 125 but no more.
#define DEFAULT_MAX_ACCELERATION {9000,9000,100,300} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
Raise this one as well to 1800 and go up from there if direct and 700 if geared
#define DEFAULT_RETRACT_ACCELERATION 300 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
Edited 2 time(s). Last edit at 05/05/2015 09:15PM by ggherbaz.
May 10, 2015 11:22AM
I ended up reducing the feed rate by quite a bit, down to 85. It has helped with the loops/waves but now I have to adjust all the infill again it seems. Oh the joys of Diy...
May 10, 2015 08:12PM
If you are using Slic3r you can adjust them under the Advanced section for infill, perimeter and so on. You should not have to if everything is calibrated on a good printer but they allow it in case.
