What should the external temperature of E3D hot end be? May 10, 2015 02:53AM |
Re: What should the external temperature of E3D hot end be? May 10, 2015 04:43AM |
Re: What should the external temperature of E3D hot end be? May 10, 2015 07:39AM |
Re: What should the external temperature of E3D hot end be? May 10, 2015 09:48AM |
Re: What should the external temperature of E3D hot end be? May 10, 2015 05:46PM |
Re: What should the external temperature of E3D hot end be? May 10, 2015 05:54PM |
Re: What should the external temperature of E3D hot end be? May 11, 2015 12:14PM |
IR thermometers accuracy varies greatly based on the emissivity coefficient of what is being measured. Every substance ranges from 0 to 1 with 1 being a perfect radiator, or a "blackbody". Most heat blocks are made of aluminum and have a emissivity coefficient a small fraction of that of a blackbody. Unless your IR thermometer was specifically designed to measure something with very low emissivity, it will be useless in getting an even remotely accurate reading.Quote
rtrahms
When I point an IR thermometer at the hot end, I get a temperature that is much lower - not 220, but more like 130 deg C.
Re: What should the external temperature of E3D hot end be? May 21, 2015 01:19AM |
