New E3D refuses to extrude May 13, 2015 09:53AM |
Re: New E3D refuses to extrude May 13, 2015 12:16PM |
Re: New E3D refuses to extrude May 13, 2015 02:45PM |
Re: New E3D refuses to extrude May 13, 2015 09:12PM |
Re: New E3D refuses to extrude May 13, 2015 09:20PM |
Re: New E3D refuses to extrude May 13, 2015 09:26PM |
Re: New E3D refuses to extrude May 14, 2015 06:37AM |
Re: New E3D refuses to extrude May 14, 2015 08:52AM |
Re: New E3D refuses to extrude May 14, 2015 09:33AM |
Re: New E3D refuses to extrude May 14, 2015 10:21AM |
Re: New E3D refuses to extrude May 16, 2015 11:20AM |
Re: New E3D refuses to extrude May 17, 2015 07:44PM |
Re: New E3D refuses to extrude May 20, 2015 06:45PM |
Re: New E3D refuses to extrude May 31, 2015 11:55PM |
thetazzbot
Don't trust assembled hot ends. You should re-assemble them following the official instructions.
Clues:
Like Riann said, but you need to heat the hot end up to properly assemble it because metal expands and will loosen. So heat it up, tighten the brass nozzle all the way in (official instructions say back it off 1 turn, but meh...)
make sure the heat sink and the heat block are not touching
and finally, make sure the PTFE tube (bowden or whatever) is seated in the top end of the stainless pipe.
The threaded ends of the brass and stainless should connect inside the heat block with no gap!
