Avoid crossing perimeters (slow) option?
Posted by Ralphy
May 25, 2015 12:07PM
Can anyone contribute some insight on what the slic3r option "Avoid crossing perimeters (slow)" is for?
I found that many files do not slice if this option is checked on.
Re: Avoid crossing perimeters (slow) option?
May 26, 2015 12:42AM
Let's say you have two cubes side by side
[ A ] [ B ]
the [ ] are the perimiters.
If the slicer wants to go from A to B, it could sometimes calculate a path from the left [ of A all the way to the left [ of B. This will cause it to cross the right ] of A.
This is "crossing the permiter of A"
So this tells the route planner to look for a way to go from A to B without crossing. So it will try to go from the right ] of A to the left [ of B.
Hope that helps.
In more complex shapes, it could have the G code travel the nozzle around the interior of your print to go from point A to point B looking for an exit to cross over.
Edited 1 time(s). Last edit at 05/26/2015 12:42AM by thetazzbot.
May 27, 2015 09:30AM
cool that makes sense, thanks. Having it checked on generates a better print?
On my complex shapes it wont make the g code with the option turned on.
thetazzbot
[ A ] [ B ]
Hope that helps.
