prusa i3 bottom layer help
June 08, 2015 08:01AM
hi
i am using curaengine slicer on repetierhost
[imgur.com]
i dont what setting i did messup, because on left side bottom layer is solid but now when i print all the prints bottom looks like that.
so how do i fix this.
thanks.
Anonymous User
Re: prusa i3 bottom layer help
June 08, 2015 06:01PM
Looks like your nozzle may be too high when the print starts. Have you calibrated the home position for the Z axis?
June 09, 2015 07:14AM
Thanks, Yes, first time and it did print solid bottoms , but i try to calibrate again. Thx..
edit:nope. it didnt work.
Edited 1 time(s). Last edit at 06/09/2015 08:55AM by heipp123.
June 09, 2015 10:10AM
Hi
Check your belt tension, the infill does not touch the walls.
Also look if your nozzle is not jam. do you have enough material going out? or temperature enough?.
June 09, 2015 12:37PM
i am using these setting came with the printer
[imgur.com]
i think my belt is tension is good. nozzle is not jam flow good.
i have change the tempeture 190-240.
thanks.
edit: well i tighten the belt and cleaned nozzle but still same.
Edited 2 time(s). Last edit at 06/09/2015 02:36PM by heipp123.
June 10, 2015 08:54AM
Hi
Ok Try this for mini maxi
print 25 30
travel 40 60
first layer 20 25
outer 25 30
inner 30 40
infill 25 35
first layer height 0.25
first layer width 200%
print and check a first layer first, if all the lines are joining, no gap then continue.
I will say for the rules (but can change) first layer you want to print slowly ~80 of your print speed, you must place max material width 200% and you need to press it to the bed for max sticking so height 0.25mm. need to measure that if possible.
travel, you can go at 100%. but never for small printer. your motors aren't big enough to accept that.
June 10, 2015 03:25PM
thanks.
[imgur.com]
i tested it and the bottom part ("first layer") is the worst and up there everything its ok even top is solid(put why bottom isntconfused smiley). the second layer is solid/flat.
(pic 2 ) in side view, its looks like its not even connected.
thanks.
Edited 1 time(s). Last edit at 06/10/2015 03:33PM by heipp123.
June 11, 2015 06:46AM
Hi
Can you give us all the page setting?
did you try another slicer? change cura and keep the same settings on the top.
better also give us pictures of the part on the bed. with the first outside layer. and side.
June 11, 2015 08:34AM
all the setting pages are in the [imgur.com]
the slicer did the same thing.
i try to upload more pic as soon as possible.
Edited 1 time(s). Last edit at 06/11/2015 08:35AM by heipp123.
June 11, 2015 02:01PM
Hi sorry guys for bothering you. [m.imgur.com] i think i just have bad heatedbed level calibration
thanks for the help guys.
June 12, 2015 03:47AM
HI
It may be possible, because last time in your settings you have 0.4mm and I corrected it at 0.25.
Better try again. Also calibration first.
June 12, 2015 07:24AM
I actually took advantage of the Misumi promotion that ended in March and bought aluminum 3030 extrusion to build an enclosure. The frame is assembled but I haven't had a chance to enclose it yet (I'm thinking about plexiglass, but it's so damn expensive). I'm hoping that will give me more consistent temperatures.
In order to get my bed to heat up to 115C, I did build a small cardboard cover that goes around the bed when it is warming up. Otherwise, it was struggling to get much past 110 in a reasonable amount of time.
