Strange kind of ... printing ...
Posted by IronG
June 18, 2015 05:26AM
Hello
My printer prints like that (image). Can someone help me out and give me some tips ?
Thnx in advance
open | download - DSC00007.JPG (229.6 KB)
Re: Strange kind of ... printing ...
June 18, 2015 05:32AM
Check the current setting for the axis motor where the print goes out of alignment.
If you do adjust higher make sure to it in small increments and to check if the motor does not get too hot during prints.
You might need a bit more juice, otherwise it could be the acceleration settings being too high.
June 18, 2015 03:01PM
You mean to adjust the stepper driver potentiometer ?
June 19, 2015 01:08PM
Lower the acceleration on the axis on which you're having the problem. In Marlin, this is the DEFAULT_MAX_ACCELERATION setting. Bring it down to 500. If that fixes the problem, raise it incrementally until you find a good balance between quality and speed.
June 21, 2015 04:41PM
Thnx i manage to solve it, but i have an other issue. The filament clogs in the PTFE tube, should i remove the PTFE ? And in which direction the tube must be? Inside the aluminum heater or opposite ?
