Small blobs since changing to E3D hot end June 20, 2015 03:54PM |
Re: Small blobs since changing to E3D hot end June 21, 2015 07:19AM |
Re: Small blobs since changing to E3D hot end June 21, 2015 01:29PM |
dc42
Can anyone who is getting good print quality from an E3D v6 on a delta or other machine with a long Bowden tube share their settings?
I recently replaced the Jhead hot end on my delta by an E3D v6. Now my standard Escher Lizard test print comes out with lots of small blobs on it:
The print on the left was done using the Jhead, the one on the right using the E3D. So far I have tried:
- Reducing the retraction from 6mm (as used on the Jhead) to 2mm (the maximum recommended by E3D)
- Reducing temperature to 180C after the first layer
- Increasing temperature to 205C
What else should I try? I currently have retraction speed set to 45mm/sec and extruder acceleration set to 1000mm/sec^2. I am using slic3r 1.2.6. Print speed is 50mm/sec for perimeters, 100mm/sec for infill. The same test print also comes out well on my Ormerod, which has a Bowden-fed RepRapPro hot end, although I have to use slower print speeds on that machine.
Re: Small blobs since changing to E3D hot end June 21, 2015 02:58PM |
tadawson
I suggest you reread the E3D page . . . 2mm is for standard extruders . . . for Bowden, they suggest starting at 5mm:
"Excessively long retractions will cause issues by dragging soft filament into cold areas, because of the PTFE liner however Lite6 can cope with quite aggressive retractions without sticking. For direct extrusion systems you should use anywhere from 0.5mm-2.0mm, for bowden systems you might want to go up to 6mm. Retraction beyond 8mm should never be necessary. A good starting point for direct systems is 1mm, and 5mm for bowden setups."
(Just noted that is for the Lite, and not base v6 . . . . would have thought they would be the same, but I guess the liner in the Lite makes it mlre tolerant . . .)
- Tim
Re: Small blobs since changing to E3D hot end June 21, 2015 04:37PM |
Re: Small blobs since changing to E3D hot end June 21, 2015 04:43PM |
vreihen
With the E3D v5, a long Bowden tube, and a geared stepper motor extruder, I'm running 6.0mm retraction @ 100mm/sec (acceleration adjusted in firmware).
Are you sure that some of the blobs are not being caused by wet filament?????
Re: Small blobs since changing to E3D hot end June 21, 2015 10:06PM |
Re: Small blobs since changing to E3D hot end June 22, 2015 12:45AM |
Re: Small blobs since changing to E3D hot end June 26, 2015 06:24PM |
IMBoring25
Is this PLA? What brand? I've seen recommendations as high as 220 for some variants of PLA, and the relatively short melt zone of the v6 means it should probably run towards the high end to keep nozzle pressure down, especially when running fast.
Are you using the same speed for normal and external perimeters? If you're not, that can exacerbate issues with nozzle pressure.
I would also second the comment that slower retraction might not hurt. 30mm/s is actually what I'm using for the moment.
Re: Small blobs since changing to E3D hot end [SOLVED] August 09, 2015 03:29AM |
Re: Small blobs since changing to E3D hot end [SOLVED] August 11, 2015 01:11PM |
Re: Small blobs since changing to E3D hot end [SOLVED] August 11, 2015 02:42PM |
Tibuck
I have been using and e3d v6 since day one , 8mm retraction seems like a lot ! at most 4.5 or even 3.5 should do the trick! at what speed did you set the retraction to ?? That plays a lot! and I also think you might be printing to hot. Don't forget every roll is deferent and e steps calibration should be done for each roll or simpler still reducing the flow rate in your slicer.
