Blobs, Blobs everywhere ! July 10, 2015 10:13AM |
Re: Blobs, Blobs everywhere ! July 10, 2015 04:45PM |
Re: Blobs, Blobs everywhere ! July 10, 2015 05:32PM |
Re: Blobs, Blobs everywhere ! July 11, 2015 05:01AM |
Re: Blobs, Blobs everywhere ! July 11, 2015 01:39PM |
ChavasRegal
If your seeing scores on the print as the extruder travels across it would seem your print bed is too high, which would catch the top layer and push to wall out as it moves. Have you got a Z hop set?
3dkarma
I think you've diagnosed your own problem - you're over extruding. The reprap wiki has some excellent advice for fine-tuning e-steps per mm to combat this. [reprap.org]
Downunder35m
I noticed that Slic§r has problems getting the extrusion right in some cases if the extrusion width is not defined.
When I leave all to the default "0" ther is no real problem in 90% of the prints, but for the rest it is a lost print due one of the follwing:
1) not enough filament for infill or top layer, but in return overflowing plastic during bridging.
2) top layer is overfilling for no reason, the layer underneath is already smooth as but during the top infill far too much plastic is used.
3) Small perimeters are filled up. Holes of under 3mm in diameter will sag and creep to a solid during printing.
After defining fixed values for the extrusion these problems disappeared completely.
Re: Blobs, Blobs everywhere ! July 12, 2015 04:42AM |
