ABS juice not sticking to glass July 15, 2015 12:51PM |
Re: ABS juice not sticking to glass July 15, 2015 01:11PM |
Re: ABS juice not sticking to glass July 15, 2015 01:34PM |
Re: ABS juice not sticking to glass July 15, 2015 01:36PM |
Re: ABS juice not sticking to glass July 15, 2015 09:40PM |
Re: ABS juice not sticking to glass July 16, 2015 03:51PM |
Re: ABS juice not sticking to glass July 21, 2015 04:37AM |
thetazzbot
Try this method that I found on youtube.
Start with clean glass. Alcohol or windex.
Pour a little acetone on the glass.
Natural white abs is preferred, but grab a failed print and just rub it on the glass all around with the acetone. It will coat the glass with abs juice.
No need to keep a jar of juice. It doesn't keep anyway, and the acetone evaps.
Re: ABS juice not sticking to glass July 21, 2015 06:25AM |
Re: ABS juice not sticking to glass July 21, 2015 07:00AM |
Re: ABS juice not sticking to glass July 21, 2015 09:08AM |
allempty
Tried to attach this photo to my previous posting but fialed, smaller file now.
This is not something on the surface, but the surface has been pulled away.
Re: ABS juice not sticking to glass July 21, 2015 11:15AM |
Re: ABS juice not sticking to glass July 21, 2015 11:39AM |
allempty
Yes I print at a bed temp of 118 degrees C and don't have distortion problems when the bed was cooler. I also don't use fans to cool the part as it's being printed. The more consistant the temperature the better.
My parts come free ok once the bed has cooled, as you say below 50 degrees C. I have wondered if I had damaged the surface with scratches from a stanly blade I use to clean off the excess ABS juice.
Have prised them from the bed with a blade, just because I get impatient !
Re: ABS juice not sticking to glass July 21, 2015 04:22PM |
Re: ABS juice not sticking to glass July 22, 2015 12:01PM |
allempty
This may have solved my problem....
