Part stretched vertically
Posted by hhbhagat
July 28, 2015 07:31PM
The part I am printing is 9.95mm in height, and the print turned out perfectly (except for one instance of acceleration issues and filament missing the mark). The actual printed height is 15.58mm. This is 156% higher than original. All the other dimensions are the same. Could it be something with my steps/mm? Thanks
I am on a RepRap Prusa Mendel i3 w/ .4mm hotend
Files:
GCODE: [www.dropbox.com]
STL: [www.dropbox.com]
Slic3r Config: [www.dropbox.com]
PHOTO: [www.dropbox.com]
Edited 1 time(s). Last edit at 07/28/2015 07:34PM by hhbhagat.
Re: Part stretched vertically
July 29, 2015 04:26PM
What you got: 15.58
What you wanted: 9.95
So.. 15.58/9.95=1.56582914573
take your current Z esteps value and add that number to it.
But, there is an easier way! smiling bouncing smiley
What is driving your Z axis? lead screw? threaded rod?
If you have threaded rod, somewhere it should say "M(some number) 2000mm x 0.8" or something like that. In this case the pitch of the threads is 0.8mm per revolution. This will work with leadscrews too, but I don't know how they are labled.
go to prusaprinters.org and scroll own to where it says "Steps per millimeter - leadscrew driven systems". Input your motor pitch, microstepping, and everything else you know if it asks for it.
smiling smiley
Master Tinkerer
July 29, 2015 04:45PM
Montiey
What you got: 15.58
I think you mean multiply by that. smiling smiley
July 30, 2015 01:30PM
I measured my rods and they are less than 8mm in diameter, like 7.8mm. Is that bad? I got this 3D printer preassembled so that's my source of confusion here. My current value for my Z Steps is 4000.
August 05, 2015 02:24PM
7.8mm when measured by calipers are common. If you're using conventional z-axis lead screw, 8mm diameter with 1.25mm pitch, z axis steps/mm should be around 2560
