Z Axis Homing Head Crash
Posted by hhbhagat
July 31, 2015 06:11PM
Attached is the Configuration.h
I have a RepRap Prusa Mendel i3, and every time I home the Z axis again after I calibrate it, the head will crash into the bed. The Z Steps/mm setting of 4000 has worked before, but now it suddenly doesn't?
Edited 1 time(s). Last edit at 07/31/2015 06:11PM by hhbhagat.
Re: Z Axis Homing Head Crash
August 01, 2015 07:13PM
connect your printer to your host and type in g-code M119
that will show the status of your endstops and if they are triggered or not
if it isnt being triggered when you home that axis, the head will crash.
if M119 shows that endstop isnt being triggered check to see if there are broken wires from your endstop to your board.
August 03, 2015 06:36AM
ut is also possible that your endstop is in the wrong port. raise the axis way up, and then on its way down go and manually trip all of the other end stops to see if they do anything.
