Bed autoleveling randomly does not work
August 03, 2015 03:41PM
Hi folks,
The quality of my prints have increased substantially since adding autoleveling. However, maybe one in five prints will have the following issue:
[i.imgur.com]
Notice the pattern on the brim.
To be clear, when bed autoleveling works, the print comes out perfect.
I have done the M48 test and I get 50 microns stdev, so looks like my servo is working correctly.
I was thinking perhaps I have run into this issue?
[github.com]
Anyone else have a problem with bed autoleveling?
Re: Bed autoleveling randomly does not work
August 05, 2015 10:53PM
Bump.
August 17, 2015 04:34AM
I am having the same problem, im desperate to try and resolve, have you tried any of the solutions from the link? If i change my probing to 3 arbitrary points, my printer auto levels then goes off in the completely wrong direction...
August 18, 2015 07:40AM
Would there be a chance that the print fails depending on bed temperature settings? The bed could bend when getting to 120°C in order to print ABS but be fine when printing PLA at 60°C.
August 18, 2015 09:06AM
I would think that is certainly possible, check out this thread:
[3dprintboard.com]
There is a good modification you can make to accurately tell how level & flat the bed is. I plan on doing this tonight.
Alex
