printing problemconfused smiley
Posted by Giacomi
August 13, 2015 09:06AM
hello guys i have a problem, I tried several times to print a pulley but the press I am inclined. I lowered speed and acceleration and checked the straps but nothing. help me. thank you
open | download - 2015-08-05 18.31.26.jpg (58.8 KB)
open | download - 20150811_161104.jpg (167 KB)
open | download - 20150811_161036.jpg (166.8 KB)
Re: printing problemconfused smiley
August 16, 2015 02:25AM
Have you calibrated your X and Y axes correctly? Cant tell from picture which axis it's "leaning" on.
_______________________________________
Waitaki 3D Printer
August 17, 2015 08:12AM
it is adjusted correctly you attach photos of inclination.
open | download - 20150817_141144.jpg (74.8 KB)
August 18, 2015 05:52AM
it's really odd how smoothly and evenly that is drifting, as well as the fact that is started where the gears teeth are, but not down on the base.
Do all of your other prints do that? And have you tried re-slicing that pulley?
August 19, 2015 10:27AM
Seems to be a slicer error since its one specific layer pattern that gets the offset.. What slicer do you run?
Master Tinkerer
August 20, 2015 12:36PM
Have you checked that all of the axes are smooth when moved by hand? Is your stepper current too low?
Since the gear teeth of the pulley have lots of sharp angles, it might cause some rod binding or skipping from your stepper motors.
August 22, 2015 08:52AM
I use simplify3d. I checked everything (belts, pulleys, steps, vref, changed usb cable) but the problem is always present. sometimes in the lower part.
open | download - 20150817_143936.jpg (78.7 KB)
open | download - 20150817_003544.jpg (88.2 KB)
August 22, 2015 12:24PM
How strong are your stepper motors? If you resist the motor movement with your hand, does it skip easily?
Also, when you said you checked the pulleys, did you mean that you made sure they were tight on the shaft and didn't slip?
Edited 1 time(s). Last edit at 08/22/2015 12:26PM by AlexY.
August 22, 2015 02:22PM
the grain of the pulleys was tight. engines oppose a good resistance.It is not loss of steps. but what to be?
open | download - 1438858888563-1150240071.jpg (68.5 KB)
August 22, 2015 04:07PM
Do the coordinates that show on the display drift during the prints?
If they don't, a motor skip steps or a pulley or belt slips.
If they do, your printer might very well be possessed or you managed to trigger a very odd bug.
August 22, 2015 06:20PM
Try flashing a different firmware and see if the problem goes away.
