How can I print this object? August 17, 2015 02:06PM |
Re: How can I print this object? August 17, 2015 04:56PM |
Re: How can I print this object? August 17, 2015 05:26PM |
Re: How can I print this object? August 17, 2015 05:45PM |
Re: How can I print this object? August 17, 2015 05:59PM |
Re: How can I print this object? August 17, 2015 06:03PM |
Re: How can I print this object? August 17, 2015 06:12PM |
Re: How can I print this object? August 17, 2015 06:16PM |
Re: How can I print this object? August 18, 2015 04:42AM |
Re: How can I print this object? August 18, 2015 04:56AM |
Re: How can I print this object? August 18, 2015 05:00AM |
Re: How can I print this object? August 18, 2015 05:22AM |
muntahunta
thanks
its more the type of wire tbh. im not sure on what kind I need (im not an electronics type of bloke yet )
Re: How can I print this object? August 19, 2015 10:25AM |
DaveOB
So if your supply is 12V, take 200W / 12V = 16.6 amps
If your supply was 24V, take 200W / 24V = 8.3 amps
Re: How can I print this object? August 19, 2015 10:45AM |
Montiey
Just be sure to understand that increasing voltage from 12 to 24v will not double the amperage drawn. A bed designed for 24v will not need to draw as much because it takes advantage of the higher voltage to do the work.
