Stepper motor not spinning August 18, 2015 04:14PM |
Re: Stepper motor not spinning August 18, 2015 04:58PM |
Re: Stepper motor not spinning August 18, 2015 05:57PM |
meeuuch
First and foremost:
I'm new at 3d printing, I know nothing about electricity and what not. I bought a folger tech kit prusa i3, assembled it, ran into a lot of problems, which I solved. Finally I found a problem that I can't solved. My stepper motor (one of the two on top that control z axis movement) doesn't work right. It jitters. I was told that it maybe the voltage. So I bought a multimeter (never have used one) and downloaded a page that tells you how to tune it. Problem is that It has calculations and verbage that I don't understand. I was wonder if anyone could take the time to tell me how to check the voltage on the ramps board. Tell me where to put the black cable and the red and what numbers I should get. I know it is tedious to explain things like this to someone that has no idea but I would REALLY appreciate it. Thanks again. Any info will help.
Re: Stepper motor not spinning August 18, 2015 08:54PM |
