first layer why is the infill like this
Posted by trist077
September 01, 2015 12:06PM
as the title says
Re: first layer why is the infill like this
September 01, 2015 12:11PM
It looks to me that either you don't have the Z=0 height set accurately and the head is starting too high, or you are under extruding due to not having calibrated the extruder steps/mm, or the extruder is skipping steps (which you should be able to see and hear) when printing infill but not at the slower speed at which the perimeters are printed.
September 01, 2015 09:06PM
Maybe try upping the first layer width? I use 225%
September 02, 2015 02:41PM
I agree with DC42, you'll need to balance the z offset (getting a correctly extruded layer height and width) and adjusting the extrusion multiplier (make sure you've calibrated E steps). Try printing a single wall test cube and measure the wall width with a digital caliper, see if it matches the set extrusion width.
Setting a wider first layer created other problems, and will still under extrude. The extruded filament will be wider but the gaps remain the same.
See:
Zennmasterm extrusion tutorial
Edited 1 time(s). Last edit at 09/02/2015 02:42PM by imqqmi.
September 03, 2015 11:24AM
Looks like incorrect Z homing, with the layers not smushed enough
Master Tinkerer
