Prusa i3 printer is not in the right size
September 12, 2015 09:19AM
Hi everybody!
I have a small problem with my Prusa I3.
I print a square that is 100 x 100 x 5mm (ABS)
The height fits 5mm
But it measures only 99.5mm in x and y
All parameters match:
"Belt Calculator Repetier Host"
Pulleys screws are tightened.
Stepper motor should have the right current
They do not lose steps.
The Printing speed I have set down to 40mm / s
Belts I tightened up a bit, I dare not tighten them too much.
Can my belts be the problem ??????
If the temperature is too high ??????
Head = 255C
bed = 120C
I have the same problem in both Repetier Host and Cura.
Here's my Cura setup.
open | download - Cura_profile.txt (10.9 KB)
open | download - IMG_20150912_151503.jpg (454.3 KB)
Re: Prusa i3 printer is not in the right size
September 12, 2015 09:49AM
Maybe x and y calibration in Marlin.
September 12, 2015 10:39AM
As Putzer said -> Calibration. Did you calibrate the axis well?
Also I have never printed in ABS (I hate the warping issues and my heated bed never reaches 100°C) I have heard that ABS prints often suffer from shrinkage.
Blog: Capotexl
Filament Factory - How to build your own cheap filament extruder
Frankenstein Laser Engraver
Make the world a better place
September 13, 2015 09:30AM
Putzer
Excuse me, but I can not see that it makes any difference Marlin or Repetier Host smiling smiley
September 13, 2015 09:41AM
ianmcmill
I had the same problem, but I have solved with a silicone hot plate (220V) and a Solid State Relay
Now I have no problems.
I print on a plain sheet of glass with ABS juice.
[:AAQ:AU:1123" target="_blank" rel="nofollow">www.ebay.com.au]
[www.ebay.com.au]
open | download - IMG_20150913_153731.jpg (579.5 KB)
