improvement help
September 23, 2015 02:22PM
using simplify 3d printing a bed leveling part ive corrected bed level 3 times and if i print centre the first layer is worse
so bed level but still have a little bed nozzle touching in photo
secand problem when infilling it does not go all the way to the right whats wrong see photos
final part good apart from the inill not touching prrimeters
layer 1
layer 1
layer 2
layer 3
final piece
Re: improvement help
September 23, 2015 02:48PM
Calibrate your machine and set it up properly.
First the mechanical basics need to be top before messing with slicing settings and other software things.
September 24, 2015 03:56PM
I checked all and it's calibrated will try printing with repetier see what happens
September 24, 2015 04:35PM
Looks like a severe case of backlash, infill not touching the perimeter on one or two sides, infill lines are in pairs with a gap between pairs. Hold the x or y motor and move with your other hand the hot end or printbed. Is there a lot of play, or springiness? Are your belts tight? Is the print surface firmly clamped down? Is the hot end firmly attached to the x carriage or extruder? Are there idlers moving up/down when the direction is changed? Are the linear bearings tight without play?
What about the acceleration? First layer print speed? Try 1500mm/s2 as acceleration for x, y and e. z depends on type of printer. First layer speed betwern 15 and 20 mm/sec.
Once you've fixed this issue, you can try adjusting the z offset for the proper first layer height, then adjust the extrusion multiplier.
Edited 1 time(s). Last edit at 09/24/2015 04:36PM by imqqmi.
