infill correction
October 03, 2015 12:16PM
as in photo starts from secand layer first layer perfect get solid lines then get dotted rough lines does so many solid then so many dotted over again till the end of the layer
using pla 207degree simplify 3d 30% infill 1 perimeter prusa i3
Re: infill correction
October 03, 2015 12:25PM
its also done dotted lines not solid at all on the perimeters as of the 3rd layer
e3d v6 0.4 nozzel all clean fan on heatsink powered direct to power supply
October 03, 2015 06:49PM
It looks like you are under extruding
Edited 2 time(s). Last edit at 10/03/2015 06:50PM by tmorris9.
October 03, 2015 11:47PM
Have you calibrated your extruder so it extrudes 100 mm of filament when you tell it to? I agree. You look like you are under extruding.
October 04, 2015 03:41AM
The first layer seems to be underextruding but I'd fix the irregular extruding problem first. Does the extruder run smoothly or intermittently, with pauses? Check motor current, extruder idler too tight or not tight enough, is the filament spool running freely? Is the hot end temperature indicated correct? Check with a thermo couple or try a print temperature 10 degreez higher and lower. Is the filament slipping? Is the hobbed bolt clean? Are the teeth deep enough, is it properly aligned with the ikament feed? Is the stepstick chip overheating? Is the extruder motor making skipping noises?
