Wavy first layer
Posted by SteveKing84
Wavy first layer
October 17, 2015 03:56PM
For the life of me I can't get a decent first layer. I'm not quite sure what I am doing wrong. I've printed litterally hundreds of models and everything I print that has a somewhat decent sized bottom surface comes out real crappy. I'm printing with a Wilson TS with auto leveling, using Slic3r. Two photos below show the problems I'm having. The smaller photo is pretty much the best I can accomplish. My extrusion calibration is dead on, I've tried varying nozzle heights from the bed, I've tried printing on an alcohol cleaned glass bed and glue stick on the bed as well. I get pretty much the same results. I seem to be just fine in all the other layers. Anyone have some ideas of what I'm missing here?
Re: Wavy first layer
October 18, 2015 04:18AM
I'll hazard a guess that you're using PLA?
Try changing the Top/Bottom infill to concentric and see what you get.
_______________________________________
Waitaki 3D Printer
October 18, 2015 04:53AM
Seems like your printer has some backlash as the infill lines seem to be jammed together in pairs. Because that practically means it's printing one line on top of the other a part of the filament curls up. You'll probably also find you could be over extruding by as much as 15% to fill in the gaps in the solid infill. Tighten the belts, make sure the z smooth rods don't bend by bracing the tighener on the x smooth rods or the z axis may bind and the x belt may not be tightened enough. Also check the idlers aren't moving up/down on direction changes. Tighten everything down, recheck all fasteners on the y carriage.
Your printer model doesn't seem to have an x belt tensioner. It needs to be really tight, you can't do it with shortening the belt on the x carriage. Belts may loose tension over time. See if you can mod your printer with this thing:
http://www.thingiverse.com/thing:845768
As for bed adhesion, most people use blue painters tape from 3M or premium tape from tesa. I used clear table vinyl at about 40 degrees bed temperature.
Print slow, about 15mm/s for the first layer. Try increasing or lowering the hot end temperature.
Edited 1 time(s). Last edit at 10/18/2015 05:28AM by imqqmi.
October 18, 2015 06:58AM
Does that bottom layer peel away from the part easily?
October 18, 2015 10:01AM
Thanks for the help guys.
Yes I am using PLA. I'll check my slic3r settings a little closer to see if I missed something on extrustion for first layer. My printer actually does have a X-axis tightener, I just checked the belt and it could be tighter, seems that's loosened over time but I still wasn't able to get good prints when it was tight.
The comment about the first layer peeling away - No problems with that, I have good cohesion. The first photo has some support material that hasn't been removed, if that's what you are refering to.
October 18, 2015 10:03AM
Try tweaking the First Layer Extrusion Width. I have mine set to 200% and the first layer goes down perfect every time. It might also be too high of a nozzle for the first layer.
Master Tinkerer
October 18, 2015 11:36AM
Well I know the second photo is too high of a nozzle, the first one should be right in the ballpark. I'll tighten up some pulleys and play around with first layer extrusion.
