Regular maintenance messed up my printer!
Posted by gmckee
October 17, 2015 09:59PM
Yesterday I updated my firmware to the latest version of Marlin, ran PID on bed and hotend, disaasembled hotend and cleaned it out, and leveled the bed (which I hadn't done for 3 months due to my nylon nuts holding the bed perfectly level). The only setting I changed was z axis feed rate from 1mm/s to 2mm/s. I have attached a picture of my test cube. All other print settings are the the same.
Edited 1 time(s). Last edit at 10/17/2015 11:03PM by gmckee.
Prusa i3 Rework - Ramps 1.4 - E3d Lite6 - Full Graphic LCD Controller
Re: Regular maintenance messed up my printer!
October 17, 2015 11:22PM
You did not say if you used your old EEPROM settings in the new firmware or if you just flashed a clean version.
If not spefically designed for your machine you will always have to do some tuning.
October 18, 2015 04:09AM
Did you use slic3r? Did you update it recently? V1.2.8 onwards has a problem with narrow walls overextruding.
Did you try reverting back to the od fw? It may have introduced some problems.
October 18, 2015 10:51AM
I used same firmware settings and double checked using the prusa calculator. I have been using cura as slic3r would export gcode for a while. I'll try old firmware after I hook up the old computer I have it on
