My heatbed is not reaching the required temperature. It reaches around 52 C max. I have it wired to 24 V should I use the 12 V connection instead? I have measured the voltage across it when heating at 11.7 V and when printer switched off resistance about 5 ohm?
Get a 24V psu if your board supports it. It will heat much faster and reach higher than 130 degrees (I haven't tried higher, as it'll trip the safety threshold around 140 degrees I think). It's mandatory for ABS, nylon and HIPS if you use PVA glue. It doesn't adhere very well at lower temperatures than 105 degrees or so in my experience.
