What is happening to my corners?
Posted by Hephaestus0000
Re: What is happening to my corners?
August 07, 2016 11:51AM
@ OP What's your nozzle diameter?
August 07, 2016 05:08PM
Your cooling fan may be set too high. If PLA cools too quickly it curls upward and corners are more susceptible to this. If you have it at 100% try 60% then 50....
August 07, 2016 07:55PM
is it not ABS cools too quickly it curls upward tmorris9, the quicker I cool my PLA print the better they come out, but abs I print with no fan most of the time, the slower they cool the better
Edited 1 time(s). Last edit at 08/07/2016 08:02PM by deaconfrost.
August 07, 2016 08:58PM
I had a similar problem years ago printing PLA, came here and someone told me to turn my fan down as it 'was' cooling it too quickly, turned the fan down and it solved my issue 100%. Just passing on wisdom I learned here. If your fan pushes enough air PLA can indeed cool too quick. Maybe not on your machine but it did on mine. And it might on the OPS.
The person that told me that started out by saying "it might sound counter intuitive but...".
Edited 2 time(s). Last edit at 08/07/2016 09:00PM by tmorris9.
August 07, 2016 09:33PM
thats weird,
anyway I too have a folger crap prusa i3 as OP and I also use a genuine e3d v6 hotend, the difference is I use gear extruder on bowden and OP has a flexi drive
Edited 1 time(s). Last edit at 08/07/2016 09:35PM by deaconfrost.
August 11, 2016 01:33PM
Hey,
Printing small (single)objects will always cause problems.
I had the same problem, cooling the part will solve that problem, although not for very small objects.
And btw I also print at a high speeds. I fall asleep printing at 30 or 50 mm/s...grinning smiley
Chris
