lousy prints, Please help, November 07, 2015 11:43AM |
Re: lousy prints, Please help, November 07, 2015 03:52PM |
Re: lousy prints, Please help, November 07, 2015 04:05PM |
Re: lousy prints, Please help, November 08, 2015 06:17AM |
Re: lousy prints, Please help, November 08, 2015 08:54AM |
Re: lousy prints, Please help, November 08, 2015 02:18PM |
Re: lousy prints, Please help, November 08, 2015 02:55PM |
Re: lousy prints, Please help, November 08, 2015 05:37PM |
Re: lousy prints, Please help, November 08, 2015 05:54PM |
the_digital_dentist
I think you have calibration problems. I don't know where the idea of measuring wall thickness came from for calibrating, but it's a bad idea. It is too difficult to measure a single wall thickness accurately and precisely. If there's any Z wobble the wall will measure thicker than the lines that make it up. When you calibrate you want everything set at the base point- set extrusion multiplier and flow to 1 and leave them alone. Measure your filament diameter in 20-30 places and with the caliper set at different orientations on the filament and calculate the average diameter. Use that average when you calibrate.
If your machine consistently over or under extrudes, the way to fix it is to address the real problem and calibrate. Triffid Hunter's calibration guide, especially the "E Steps Fine Calibration" section will get your machine calibrated right.
Things like flow and extrusion multiplier are used to tweak prints on the fly when you reuse gcode that was sliced for one diameter but now are running filament of a different diameter. Read through the stuff about volumetric extrusion- you set one filament diameter when you slice, then set the actual diameter when you print, either via host or LCD panel depending on your firmware (smoothieware has a filament diamter input via the LCD/encoder panel). By using volumetric extrusion, your gcode becomes filament diameter agnostic. You can reuse the gcode with any diameter filament. Going further, if you set the bed and extruder temps to 0 when you slice, you then set them when you print, depending on the material you are printing. If you use both of those tricks, your gcode will be usable for any material and any diameter filament.
