Vertical ABS cracks November 16, 2015 01:28PM |
Re: Vertical ABS cracks November 16, 2015 01:33PM |
Re: Vertical ABS cracks November 16, 2015 01:41PM |
Hi. That is an intresting idea. Over extrusion? However that part is only 2mm thick, and width is 0.4mm.Quote
Downunder35m
It looks like you print with a 100% infill.
That can cause a lot of stress as the material can't go anywhere.
If possible try with less infill, let's say 85% or with a slightly lower print temp.
Try to find the balance between proper layer adhesion, infill level and print temp.
Re: Vertical ABS cracks November 16, 2015 05:04PM |
Re: Vertical ABS cracks November 17, 2015 01:36AM |
Re: Vertical ABS cracks November 17, 2015 02:24AM |
