Prusa i3 ruining my life
November 30, 2015 11:12PM
Hey guys. I just built a Prusa I3. I have been able to print stuff with normal speed settings and temps around 205 but they're not that great. Gear teeth are sloppy and round etc. Not perfectly straight lines etc. So im trying to dial my settings in to print slower and more accurate. Here are the setting for slicer and pics of my test. Im printing with 1.75mm Shaxon PLA.
problems I see:
strings
squished base
thank you! this is driving me nuts!
edit: added screenshot of speed settings, oops
Edited 1 time(s). Last edit at 11/30/2015 11:16PM by davidbananas999.
open | download - ice_screenshot_20151130-174803.png (48.6 KB)
open | download - ice_screenshot_20151130-174740.png (36 KB)
open | download - ice_screenshot_20151130-215945.png (243 KB)
open | download - IMG_2819.JPG (105.4 KB)
open | download - IMG_2817.JPG (145.9 KB)
open | download - IMG_2816.JPG (130.8 KB)
open | download - IMG_2818.JPG (137 KB)
open | download - ice_screenshot_20151130-220618.png (54.9 KB)
Re: Prusa i3 ruining my life
December 01, 2015 02:28AM
Your bridging speed is too high and you need to tune the retraction to avoid the strings.
December 01, 2015 03:42AM
205C seem to high. Especially when you print slow. Stringing happens with high temp,low retraction speed and retraction length.
190C, 80mm/s and 2-4mm are good values to start with.
The part is so shiny, are you sure it isn't PETG?
Olaf
PS: Don't be such a crybaby winking smiley We all have spend time and tons of filament to get it right. Print some calibration cubes and go from there..
Edited 1 time(s). Last edit at 12/01/2015 03:45AM by o_lampe.
December 01, 2015 08:21AM
There are no bridges there. I'd say the travel speed at 30 is way too low; gives too much time for nozzle to drain (esp PLA).
Also looks like retraction is turned off. Need to be on; I'm using 2mm at 20 mm/s.
December 01, 2015 06:24PM
Next Test:
I have included a couple pictures of my latest test print with new settings. Remember this is 1.75mm pla.
Problems:
large spikes
stringy
squished base
settings:
layer height 0.2mm
fill density 40%
no support
extruder multiplier 1
extruder temp 180ºC
bed temp 70ºC
nozzle diameter 0.4mm
retraction length 3mm
lift z 0
retraction speed 80mm/s
(see attachment for speed settings)
I appreciate any tips, thanks.
open | download - IMG_2824.JPG (110 KB)
open | download - IMG_2823.JPG (92.7 KB)
open | download - IMG_2822.JPG (126 KB)
open | download - IMG_2821.JPG (119 KB)
December 02, 2015 04:35AM
70C bed temp is only required for prints on sheer glass. With blue painter tape you can lower the temp to 45ish. => less squishing
The corners of the object look like you have loose belts or otherwise play in your mechanics. ( low budged linear guides? )
Don't expect to print parts, you don't need to clean up afterwards.
-Olaf
PS: The part is still very shiny, I haven't seen that with PLA before. confused smiley
Edited 1 time(s). Last edit at 12/02/2015 04:36AM by o_lampe.
December 02, 2015 06:00AM
I have a white PLA that is quite shiny too winking smiley
December 02, 2015 08:11PM
my kit was pretty cheap. what are the linear guides, and do you have a link to some decent ones?
Also I have my belts are as tight as i can set them, should i use s clips or something? im just going to print some anyway to try it
ty
December 02, 2015 08:56PM
Just do a search on Ebay for 8mm linear bearing and you will find plenty.
Some people started to print those bearings as simple sleeves in Nylon and claim it works great.
A problem with many kits is that you literally get what you pay for, so if you buy low end you can not expect high end quality prints or insane speeds.
If you just finnished the build and try to get it running start by using silicone oil on the moving parts and just let the machine work all axis for 2 or 3 hours - this takes care of most things that are still binding and causing too much friction.
After that move by hand what can can be moved by hand and check if it runs smooth.
Sometimes a slight twek in the rod alignment can have surprising results, half a mm difference can be the difference between a smooth ride and failed prints.
December 05, 2015 06:22AM
Still looks like there is no retraction at all. I thought there was no bridging, but I see it there now.
At 80 mm/s retraction speed, mine would just buzz (skip) and not retract much. Reducing to 40 helped most of the time, and reducing to 20 works every time. Yours might be skipping on retraction too, and if so, you are getting no retraction.
