Filament jamming
December 04, 2015 03:53PM
I finally found the location of my jams but not the cause. Can anyone help? As seen in the photo, it appears that the filament is getting bunched up just ahead of the heater. Worked ok the other day; same filament and dimensions are within spec. I thought about tapering the inlet, but would appreciate anyones thought about why this is happenning. Thanks.
open | download - image.jpeg (106 KB)
Re: Filament jamming
December 04, 2015 03:59PM
Looks like serious heat creep. Is there actually any cooling for the hotend? The part after the bolt/gear should usually reach more then about 30-40C.
[www.bonkers.de]
[merlin-hotend.de]
[www.hackerspace-ffm.de]
December 04, 2015 04:29PM
Thanks for the reply. I do have the hot end fan running continuously. What is also happening is the z dimensions is not changing resulting in no filament getting out. That may be causing a constipated heater. But the motor works as I can still control it. Thoughts?
December 04, 2015 04:30PM
By the way, running pla at 200C.
December 05, 2015 03:55AM
Are you sure, you have an hotend for 1.75mm filament or is it drilled for 3mm?
It looks like the hotend is pushing up the molten filament.
-Olaf
December 05, 2015 04:31AM
Something is definately too wide or missing...
