Huge infill suddenly...on Slicer too.
Posted by davidbananas999
December 18, 2015 04:05PM
All of my models suddenly started printing the infil way blown up for some reason. Slicer is making the layers like that when sliced. I havent changed any infill options. The picture is a cube with honeycomb 20% infill.
Thanks for any tips!
Edited 1 time(s). Last edit at 12/18/2015 04:06PM by davidbananas999.
Re: Huge infill suddenly...on Slicer too.
December 18, 2015 05:55PM
i figured out it happens when i change my layer height in slicer from 0.3 to 0.1. Any idea why that would cause the infil pattern to be much larger?
December 20, 2015 01:43AM
I've read about the new Slic3r having bugs. Mine works fine.
December 20, 2015 07:01AM
With Slic3r you either need to set all extrusion widths to set values or set them all to zero and use the volumetric calculations for the extrusion.
Leaving some values to zero and adjusting others brings Slic3r into a bad mental state.
December 28, 2015 10:43AM
Did you swap filaments, or layer height, or anything else besides the infill settings?
Master Tinkerer
January 03, 2016 08:36PM
Looks like 5% infill.
