Hi. Wondering if anyone has some advice to further tidy up my prints. I've calibrated and gone through the calibration guide from the wiki. I stopped at oozebane test (which I think is the problem with my print in the images). I stopped because in repetier / slic3r I can't find the options it is talking about for doing the calibration for ooze.
I think what is happening is when it moves the ooze from the nozzle is catching on the print as it meets the perimeter and just builds up from there. Generally is only an issue on larger prints.
I find I start to see ooze as soon as the hot end has heated up (it especially causes me problems at the beginning of a print because whilst it waits for the 30 seconds or so warming before printing it causes a blob which is really tricky to get off whilst the head is moving. It comes out in a string but I guess static or something causes it to curl up onto the hot end and make a small blob.
Geeetech Rostock G2S Delta printer
PLA
200 degrees hot end with hotbed at 55 degrees
Hot end fan running constantly
Latest version of repetier / slic3r GCode attached (zipped because of upload size limits)
I'd reduced the feed rate on repetier manual control to 70 during printing
Thanks for any help!
