Prusa i3 Z axis not rising high enough halfway through print December 30, 2015 08:16PM |
Re: Prusa i3 Z axis not rising high enough halfway through print December 31, 2015 03:01AM |
Re: Prusa i3 Z axis not rising high enough halfway through print December 31, 2015 10:03AM |
o_lampe
You either have your e-steps calibration wrong or your z-steps.
What kind of lead screws do you have? The pitch is important to know.
Also the diameter of the extruder drive gear to estimate the right e-steps.
You can see calibration guides here
The other problem might be, binding on the smooth rods from very tight x-carrier belt.
Or your z-stepper current is too low and skips steps.
-Olaf
Re: Prusa i3 Z axis not rising high enough halfway through print December 31, 2015 01:25PM |
Re: Prusa i3 Z axis not rising high enough halfway through print December 31, 2015 06:38PM |
chrispytoes
My e-steps are 152 which I read was correct for the MK8 extruder
Re: Prusa i3 Z axis not rising high enough halfway through print December 31, 2015 09:41PM |
Re: Prusa i3 Z axis not rising high enough halfway through print January 03, 2016 11:29PM |
Re: Prusa i3 Z axis not rising high enough halfway through print March 01, 2017 07:52AM |
Re: Prusa i3 Z axis not rising high enough halfway through print March 01, 2017 08:40AM |
