Strange ripple on only x axis
Posted by Rooski
Re: Strange ripple on only x axis
April 21, 2016 03:31AM
Ripple Eliminator
[www.thingiverse.com]
April 21, 2016 06:19AM
Just use the Silentstepstick and they will be gone. Btw with these the noise is although gone.
April 21, 2016 02:34PM
Kev0
Can you use the SilentStepStick directly on the RAMPS board? I've read that you need to solder a few wires to enable the spreadCycle mode. Would there be any commercial units with the required modifications?
April 21, 2016 02:58PM
Its totally easy to wire the config, just one wire across the cfg1 pin to GND . Just search for the documentation of the silentstepstick.
You may use 24V since then the drivers will run smother and with less noise.
April 21, 2016 03:35PM
Kev0
I had ordered the ones on the link . In the explanation, they only tell you to remove microstepping jumpers and install the driver. Would that work or should I remove the cfg1 header and solder it to the ground?
April 21, 2016 11:14PM
As you said, remove your jumpers on the board, dont solder cfg1-3 pins on the driver (remove them with pliers before soldering), and cross a wire from cfg1 to gnd.
April 22, 2016 04:41AM
They come pre-soldered I think but heating with soldering iron should allow me to remove them.
April 22, 2016 08:32AM
That 1A current seems pretty limiting - even my nema14s take more than that. I guess you could shop around for high impedance motors with lower current ratings and run them at 24V.
April 22, 2016 08:43AM
Its not 1 A! Just search before complaining about.
Its 1.2 A RMS wich equals about 1.7 A Imax
April 22, 2016 08:58AM
The vendor in the provided link states 1A max. It's unusual for a vendor to under sell their product so I took it at face value, but you are right, the chip data sheet states 1.7A motor current per coil. Which compares to the 2.5A rating on a drv8825 costing $2. They still look a little under powered to me, especially for the price. Do you sell them or just like them a lot?
April 22, 2016 09:24AM
I just like them a lot since they solved my issue, and btw the noise is gone.
May 05, 2016 07:01AM
@jamesK
did you solve the problem? i am having a similar issue
reprap forum
May 05, 2016 07:04AM
ekaggrat
@jamesK
reprap forum
When I was using DRV8825 with an ungeared extruder the problem was much reduced when I added the inline diodes as per [cabristor.blogspot.ca]
