Cura says 0 minutes for print?
January 14, 2016 05:25PM
I imported an STL file into Cura from thingiverse and it shows the print time as 0 minutes. It should take a lot longer than even 1 minute. Any idea how to fix this? Here's the file:
[www.thingiverse.com]
PS: So far I've only encountered this problem with this part.
Edited 2 time(s). Last edit at 01/15/2016 03:46AM by printingandprinting.
Re: Cuba says 0 minutes for print?
January 15, 2016 02:27AM
I openend the part with netfabb and it showed errors. I tried to fix them twice, but the error still exists. Ask the designer, what slicer he would recommend.
-Olaf
Edited 1 time(s). Last edit at 01/15/2016 02:27AM by o_lampe.
Re: Cura says 0 minutes for print?
January 15, 2016 10:52AM
I fixed it in solidworks. That original file was messed up something bad.
open | download - air stand.STL (13.9 KB)
January 20, 2016 04:01AM
Wow, thanks, I appreciate it Floyd. How did you fix it?
January 20, 2016 01:58PM
I ended up just re making it from scratch by reverse engineering the model. Maybe 5 minutes for this simple part.
Glad you got to make the part you wanted! Always looking to help people out.
January 20, 2016 06:57PM
Floyd
smileys with beer
