typical values for spd/acc etc for i3 rework
Posted by friarfish
January 17, 2016 05:35AM
Hi folks,
The rework has been printing now for 3 days and behaving itself apart from some strange
surface issues. I am wondering what seem to be the maximun values for speed etc
other people have gotten to with i3 etc.
I've currently got MAX_FEED 150,150,4 and MAX_ACC 10000 6000. Slicer is setup
to perimeter 50mm/s and infill of 80mm/s.
Can they go much higher? Or have i pretty much hit the limits?
Many thanks,
Andrew
Re: typical values for spd/acc etc for i3 rework
January 17, 2016 10:53AM
With M5 leadscrews, you are lucky to get 4mm/sec. I've reduce mine to 3mm for safety reasons.
The rest depends on your filament and extruder ( IMHO the bottleneck in my Prusa )
I've made test cubes with 120mm XY-speed and the top fill was slightly under extruded with the standard direct drive MK8 non hobbed drive gear.
Don't ask for accuracy at that speed.
-Olaf
January 18, 2016 08:05AM
Here are mine for a stee frame, E3Dlite6 Wades:
#define DEFAULT_MAX_FEEDRATE {200, 200, 3, 45}
#define DEFAULT_MAX_ACCELERATION {800,800,50,5000}
#define DEFAULT_XYJERK 15.0
#define DEFAULT_ZJERK 0.4
#define DEFAULT_EJERK 5.0
I think my accel or jerk is still too high. On corners I still get a bounce and some ringing; I don't like that excess force.
January 18, 2016 09:51AM
RRuser
I'm running XY jerk of 5, and also use 800 for XY accel. I was beginning to think I was the only one that run at the slower end of the range smiling smiley
I like the smoothness of the way it prints with these settings, but the print times can be a bit excessive. One day I'll get around to exploring some faster settings, but it's pretty low on the list of priorities. I design all my parts with heavy filleting, so the jerk value mostly impacts infill.
January 19, 2016 05:52AM
Hi folks,
When i saw values people have posted I was a little surprised.
Makes me wonder if my values are a bit insane.
I will admit after trying honeycomb infill twice, I switched to rectlinear to stop
my extruder/hotend from shaking itself to pieces.
