New to 3D February 01, 2016 02:52PM |
Re: New to 3D February 01, 2016 03:11PM |
Re: New to 3D February 01, 2016 03:13PM |
Re: New to 3D February 01, 2016 03:20PM |
Re: New to 3D February 01, 2016 04:09PM |
Re: New to 3D February 01, 2016 04:48PM |
Re: New to 3D February 02, 2016 12:24AM |
Re: New to 3D February 02, 2016 04:09AM |
Re: New to 3D February 02, 2016 07:21AM |
; generated by Slic3r 1.3.0-dev on 2016-02-02 at 07:12:54 ; Don't forget there may be a problem with gap fill ; ; [github.com] ; external perimeters extrusion width = 0.50mm ; perimeters extrusion width = 0.50mm ; infill extrusion width = 0.50mm ; solid infill extrusion width = 0.50mm ; top infill extrusion width = 0.50mm M80 ; turn on power G28 ; home all axes G0 X0 F3000 ; Get X axis out of the negative region, otherwise first moves are slow and noisy. M109 S260 ; set temperature and wait for it to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; reset extrusion distance G1 Z0.280 F15000.000 ; move to next layer (0) G1 E-4.00000 F9600.00000 ; retract G92 E0 ; reset extrusion distance G1 Z0.680 F15000.000 ; lift Z G1 X84.663 Y85.659 F15000.000 ; move to first skirt point G1 Z0.280 F15000.000 ; restore layer Z G1 E4.00000 F9600.00000 ; unretract G1 F900 G1 X86.424 Y84.122 E4.12144 ; skirt G1 X88.599 Y83.264 E4.24287 ; skirt G1 X90.000 Y83.120 E4.31606 ; skirt
Re: New to 3D February 02, 2016 07:41AM |
Re: New to 3D February 03, 2016 03:51AM |
Re: New to 3D February 03, 2016 06:36AM |
Re: New to 3D February 04, 2016 04:32PM |
Re: New to 3D February 04, 2016 04:58PM |
