Dual extruder config
Posted by pikelo
February 12, 2016 07:51AM
Hi guys!
I have a couple of Prusa i3 working perfectly. Then, I decided to upgrade one of them with a dual extruder set. I have tried to mount two hotend aparts each other x-axis of 24mm.
• Firstly, I tried to use 2 x Universal 1,75mm – 0.40mm nozzle E3Dv6, both of them of course with cooling fans.
Results: filament slip everytime after a few minutes.
Tried from 185ºC to 230ºC but temperatura is not the issue as filament flow fine if I push it by hand.
This was using bwoden extruders with a MK drive.
• I though it would be because this drive system and I installed two Wade extruder but bwoden system.
• Then I decided to change using 2 x j-Head hotends 1,75mm 0.35mm nozzle.
Results: filament slip after a few minutes even trying to print at 225ºC.
Finally, I though it can be a firmware feedrate issue or something else I can’t find..
I attached on slic3r screenshot of my Hephestos printer printing at 32mm/s with an awsome quality!!
And also I attach a Simplify3D screenshot of dual system trying to print speeds that is always slipping filament at that veeeery low speed: 8mm/s
I also attach a firmware feedrate config..
I really appreciate any kind of help with this frustrating issue.
Many thanks to all!
open | download - slicer_speed.jpg (201.2 KB)
open | download - Marlin_config.jpg (187.3 KB)
open | download - Simplyfy_speed_1.jpg (256 KB)
