slic3r x/y distance control in slic3r February 15, 2016 05:10AM |
Re: slic3r x/y distance control in slic3r February 15, 2016 07:05AM |
Re: slic3r x/y distance control in slic3r February 16, 2016 01:44AM |
Re: slic3r x/y distance control in slic3r February 16, 2016 04:48AM |
Re: slic3r x/y distance control in slic3r February 16, 2016 07:48AM |
Re: slic3r x/y distance control in slic3r February 17, 2016 02:18AM |
The other way is to print a test object with each spool using the spiral vase function in slicer, and specify the wall thickness and use the nominal diameter when you slice. Measure the printed wall thickness and then set the flow control for target wall thickness/measured wall thickness. Mark that flow control number on the spool and use it each time you slice to print from that spool.
Re: slic3r x/y distance control in slic3r February 17, 2016 07:22AM |
athul
I couldn't find "flow control" in slic3r ????? where to find that tab ??????????? Are you referring to "extrusion width" ??
athul
And when I use spiral vase function , how to set it?
athul
Is it like if my target wall thickness = 1mm
and measured wall thickness = 1.1 mm
then flow control= target wall thickness / measured wall thickness=1/1.1=0.9091 ?????????????
athul
And also If I use layer height= 0.2 mm and 0.4 mm nozzle what'll be my targeted wall thickness ? (There's only option to set no of perimeters in slicer not wall thickness?)
Re: slic3r x/y distance control in slic3r February 17, 2016 08:35AM |
Re: slic3r x/y distance control in slic3r February 17, 2016 10:54AM |
Re: slic3r x/y distance control in slic3r February 18, 2016 06:03AM |
