First layer, stretched lines February 26, 2016 12:49PM |
Re: First layer, stretched lines February 26, 2016 05:41PM |
Re: First layer, stretched lines February 26, 2016 07:15PM |
Re: First layer, stretched lines February 26, 2016 09:54PM |
Re: First layer, stretched lines February 27, 2016 09:15AM |
Re: First layer, stretched lines February 27, 2016 11:38AM |
I guess this more or less flips my original thought on it's head - when you get gaps like that on the glass side it tends to indicate under-extrusion or too high a Z=0 setting. What speed do you print the first layer at? I'm still doing all my first layers at 15mm/s which works well but can add a lot of print time if the first layer is big.|
Re: First layer, stretched lines February 27, 2016 11:48AM |
Re: First layer, stretched lines February 27, 2016 11:54AM |
Re: First layer, stretched lines February 27, 2016 12:13PM |
Re: First layer, stretched lines February 27, 2016 12:23PM |
Re: First layer, stretched lines February 27, 2016 01:14PM |
Re: First layer, stretched lines February 27, 2016 04:22PM |
Re: First layer, stretched lines February 28, 2016 07:28AM |
Re: First layer, stretched lines February 28, 2016 08:45AM |
Re: First layer, stretched lines February 28, 2016 09:43AM |
Re: First layer, stretched lines February 29, 2016 08:07AM |
Re: First layer, stretched lines February 29, 2016 09:21AM |
Re: First layer, stretched lines February 29, 2016 10:12AM |
Re: First layer, stretched lines February 29, 2016 10:15AM |
Re: First layer, stretched lines February 29, 2016 10:57AM |
Re: First layer, stretched lines February 29, 2016 11:29AM |
Re: First layer, stretched lines February 29, 2016 01:59PM |
Re: First layer, stretched lines March 01, 2016 10:51AM |
SteveKing84
I'm printing on an aluminum bed (still had problem on glass though), using Hatchbox (brand doesn't seem to make diff), bed temp 70, nozzle 185, when using my 0.8mm nozzle my g-code reads as is below. First layer is put down at 20mm/s. I should also mention that when I measure the thickness of my skirt it is generally +/- 0.03 of my first layer thickness.
; external perimeters extrusion width = 0.80mm
; perimeters extrusion width = 1.11mm
; infill extrusion width = 1.11mm
; solid infill extrusion width = 1.11mm
; top infill extrusion width = 1.11mm
; support material extrusion width = 0.80mm
