RepRap Fisher not extruding
Posted by grant.baxter
February 29, 2016 04:26PM
Hello,
So i recently completed a couple of prints on my RepRap Fisher printer, i have since let it cool and powered it off. I now cant extrude anything, I did see in previous posts it was suggested it was blocked however i don't believe that's the case. I have also tried giving the filament a little push to help which also doesn't work?
Any suggestions? moody smiley
Re: RepRap Fisher not extruding
March 01, 2016 03:41AM
Why don't you believe that it is blocked if it is not extruding even when the filament is pushed by hand? Filament type? Too cold hot end? If it is ABS, heat to 250C and try to extrude, few times 5mm. If not still extruding, reverse the filament, snip the end of the filament and feed again. Luckily some metal chip garbage comes out when reversing and re-feeding the filament.
Prusa i3, Ramps 1.4. Catnozzle 0.4mm
SketchUp - Enveloping Globoid Worm Gear - Part One - 3D Printed: [youtu.be]
DesignSpark Mechanical & more precise screw thread: [youtu.be]
Nicer Screw Thread In SketchUp ( Bolts,Nuts): [youtu.be]
How To Model A Heart Shape In SketchUp: [youtu.be]
How To Draw 3D Printable Snap Fit Ball Joint In SketchUp: [youtu.be]
March 08, 2016 11:58AM
yep i admit after alot of messing around it was blocked, i just couldn't see anything after feeding a thin drill bit through.
