Hello
I just built this printer last month and it was working properly, but now I cannot get a single successful print of any size. I am used to working with my brother's Robo but
this is the first printer of my own.
Everything will go correctly for a while but after a minute or so, the extruder seemingly forgets its place and just begins printing in a different place as seen in the image below.
((The print in the image below also had some other problems as you may notice but I have sorted those out))
I have tightened the strings and tinkered with the settings but nothing seems to change much. Oiling the rods will fix problem for a print or two, but it does not seem right that I would need to oil them after every print. It almost seems to happen randomly. I was considering putting some violin string rosin on the strings to help prevent slipping but I didn't want to attempt that without input from someone experienced.
Any advice is greatly appreciated
