Holes + Bad Details! Prusa I3 March 05, 2016 11:58PM |
Re: Holes + Bad Details! Prusa I3 March 06, 2016 08:15AM |
Re: Holes + Bad Details! Prusa I3 March 06, 2016 07:34PM |
Re: Holes + Bad Details! Prusa I3 March 06, 2016 07:55PM |
Re: Holes + Bad Details! Prusa I3 March 06, 2016 10:48PM |
Re: Holes + Bad Details! Prusa I3 March 07, 2016 04:33AM |
If you did not change any settings, what setting are you using for layer height and width?Quote
devilmostwanted
Ah! I see. I am not sure how the speed really works in slic3r and hence I have not changed the speed settings from default. I have it attached for you to review.
In terms of the fan, yes I do have a fan. But for that, as well, I have not touched the settings as I have no idea which setting works and how it works...
Re: Holes + Bad Details! Prusa I3 March 07, 2016 06:59AM |
Re: Holes + Bad Details! Prusa I3 March 07, 2016 12:34PM |
Re: Holes + Bad Details! Prusa I3 March 07, 2016 01:44PM |
Re: Holes + Bad Details! Prusa I3 March 08, 2016 12:05AM |
Re: Holes + Bad Details! Prusa I3 March 08, 2016 06:52AM |
Re: Holes + Bad Details! Prusa I3 March 09, 2016 12:32AM |
Re: Holes + Bad Details! Prusa I3 March 09, 2016 06:17AM |
Re: Holes + Bad Details! Prusa I3 March 11, 2016 06:22PM |
Re: Holes + Bad Details! Prusa I3 March 11, 2016 07:36PM |
Re: Holes + Bad Details! Prusa I3 March 11, 2016 09:47PM |
JamesK
No, not normal. Where is the extruder fan connected? If you have it connected to the psu 12v then possibly you have a broken/intermittent wire.
Re: Holes + Bad Details! Prusa I3 March 12, 2016 07:16AM |
Re: Holes + Bad Details! Prusa I3 March 12, 2016 11:28AM |
Re: Holes + Bad Details! Prusa I3 March 12, 2016 11:39AM |
devilmostwanted
The unit I have has a custom board where it receives two 12v inputs from the PSU. Hence it eliminates the need to connect fans directly to the PSU. In fact there is no extra space on the PSU for me to connect anything else.
I did further further investigations! I measured the output of my PSU to the board during and after the heating of extruder and the bed while PWM fan is at full speed. Here are the results:
1. During the heating process PSU provides two consistent streams of 12v (remember board gets two 12v input).
2. Once heating has been completed, the PSU starts to act a bit crazy: it makes clicking and hissing noises every, say 30 seconds, and the voltage (on both outputs) swings from 12 to about 10.90 and then back up. During this time, the LED on the PSU blinks as well.
2.1. When this happens the LED of the bed goes out and I can hear the fans slowing down.
3.I tried to lower the voltage being sent to the board from 12v to 11. Same thing happened but less frequently. Then I lowered it to its original value at 10.80 and the problem went away! Then back up to 12v and problem back!
4. When turning off the printer a hissing sound that lasts about 2 seconds comes from the PSU.
Is it safe to assume that the PSU is dying?
